I am useing RAK3172 module. I will test LoRa P2P successfully via AT commands.
But after using RAK3172 as a Stand-Alone Device I am uploading the RAK3172 (.hex) file available at hex file
to configure the device in AT command mode.
But After uploading new firmware (AT+P2P=868000000:7:125:0:10:14) command gives the error. “AT_MODE_NO_SUPPORT”
I already discussed this to the team and it will be backward compatible on the next release of the RUI3 firmware v3.5.4. Right now, the stable version is 3.5.3.
To be compatible on the new convention, you just need to update the 3rd parameter which is the bandwidth. On your test, you use 125. Therefore from
AT+P2P=868000000:7:125:0:10:14 it will become AT+P2P=868000000:7:0:0:10:14
