RAK 19003 Base board
Hi @beegee
Thanks for this help. I still have a few questions and I would be grateful if you could help me further.
I assume I can connect a push button to the RX1 and GND pins. Will this need a pull-up resistor?
Will this interfere with the serial connection from PlatformIO?
What pin number will this appear as in the code?
The example code with the Arduino button library polls the button pin from the main loop. Is there a wat to get an interrupt instead?
The 18001 buzzer I use at the moment connects to pin WB_IO3.
I assume this will change with the new 19003 base?
Alan
Hi @Alangward
Just realized that the RAK12500 is connected to both UART1 (RX1/TX1) and I2C, so you cannot use any of the pins for a button. Sorry, I complete forgot about that.
Two possible solutions:
a) use the RAK1910 (RX1/TX1 only) and use SCL or SDA for a button
b) use the RAK5005-O base board instead of the RAK19003.
We have used the RAK 1910 in the past. With the RAK 12500 I am able to turn it off until a few seconds before we need a fix - using the API. Is that possible with 1910?
Yes, you can use IO2 to shut down the RAK1910 and power it up just before you need it.
Thanks for this information. I’ll give it a try. Any idea what time it takes to acquire a fix from that state? I presume it’s doing a warm start?
Hi Allan,
It depends on the view to the sky. Unobstructed view it takes 15 seconds after cold start. In my front yard (antenna sees only half of the sky) it can take 30 second
Hello, my name is Arienne,
I am new to the forum, and I am also new to the use of the RAK for those I send questions I beg you to help me please
Looking at the device documentation I found this:
  • Fast location fix.
    • 29 s from cold start to first fix.
    • 1 s from hot start
The 29s correlates well with what you say above. But it implies there is a warm start option, which presumably draws less current than fully on. Do you know how I can select/deselect that mode.
Alan
The warm start requires the GNSS chip to be kept powered up. So far I didn’t find out how to put the RAK1910 into a mode that supports that. The RAK12500 library has functions for power saving modes, but in my tests it was rather disappointing, power consumption didn’t lower as much as expected. Don’t have values recorded, I gave up on that option quite fast.
My experiments with the 12500 were quite successful. When it was on it was drawing about 50mA, When I turned it off that dropped to 5mA for the entire board. I set the timer so that it woke up a few seconds before the main loop activated.
Will the GNSS library work with the 1910?
5mA sleep current is quite high. My tracker firmware gets down to 50uA in sleep mode :grin:
Unfortunately the Sparkfun GNSS library for the RAK12500 does not support the RAK1910. In our examples we use TinyGPS.
My own tracker firmware for RAK1910: RAK4631-Kit-2-RAK1910-RAK1904-RAK1906
And this one is for RAK12500: RAK4631-Kit-2-RAK12500-RAK1906
@ArienneGervais Welcome to the forum.
Please do not hijack existing topics.
If you have a question, please open a new topic and ask your question there.
bonjour, c’est d’accord merci
Hi @beegee
I assumed the 5mA was because the GPS was in standby and I’m OK with that . How can I find out how to put the 1910 in warm standby mode so that will get a fix in a few seconds?
Alan
Hi @Alangward
I never tried that. A good point to start searching might be the u-blox MAX-7 data sheet => https://www.u-blox.com/sites/default/files/products/documents/MAX-7_DataSheet_UBX-13004068.pdf
Hi @beegee
I had already discovered that document. I have also downloaded
u-blox 7 Receiver Description Including Protocol Specification V14.
I’m a little worried that this device appears to be ‘end-of-life’ on the u-blox web-site.
So I’m wondering how long you will be able to maintain supplies of the 1910. If our design is critically dependent on it we may run into problems in the future.
Anyway, I see it supports the UBX protocol as well as NMEA so I intend to investigate whether this gives us more control. I’ll let you know how I get on.
Alan
I am thinking about a hardware change on the RAK12500. Having the RX/TX disconnected and a solder jumper for people who needs serial communication. But that is of course nothing that will be available fast.
That would be a good move from our point of view - future proof our solution.
Alan
I have received and assembled this base board with the RAK 18001 buzzer and the RAK12500 GPS. Everything works fine except that I cannot get the buzzer to work - I assume I am using the wrong pin - I have tried changing it with no improvement.
Alan
Hi Alan,
Which Slot are you using for the RAK18001? Here is an overview for the IO to be used depending on the Slot number: RAK18001 WisBlock Buzzer Module Datasheet | RAKwireless Documentation Center
One thing we found about the Tone() function in Arduino. It can happen that the IO is staying on HIGH level after the tone was played. You need to use digitalWrite(IO, LOW) after finishing to play a tone.
