RAK7200 node, GPS tracker
Hi @smurphy,
About the issue you met, i think you can try to upgrade the firmware according to this document firstly:
https://doc.rakwireless.com/rak7200-lora-tracker/upgrading-the-firmware
If it can’t work too, you can send an email to me, and i will give you the bootloader file.
Yes of course!
We are developing a custom tracking device for the metal sheets containers that goes by truck from a warehouse to the biggest automobile manufacturer (about 1.5Km in line of sight) in Portugal: Autoeuropa (Ford_/volkswagen). We would like not use LoraWan but a custom very simple protocol and so we would like to make the first tests in p2p configuration…
As I told you I’m more in charge of the hardware development at our research group. I will ask my Colleague Ricardo Mendonça to give you more details about the software implementation!
Thank you very much for the attention,
Eduardo Pinto
Hi Fomi,
As emfpinto said in his previous post, we here only attempting to test the trackers in a simple configuration like p2p mode! However, being aware now that the firmware doesn’t support P2P mode, we moved on to the LoRaWan working mode.
Let me briefly explain now the scenario: We have built a custom made gateway/concentrator that is equipped with a SEMTECH LoRa transceiver. This gateway has been working with our custom made beacon using also LoRa modulation. This only for prototyping and it worked very well.
We now use a RAK7200 tracker to send data to our custom gateway. We configured the RAK7200 tracker to use the ABP authentication mode, and it notifies us that it joined the network succesfully and is now sending data at regular intervals. However, our gateway does not receive anything.
Maybe it is some misconfiguration between the tracker and the gateway/concentrator with the RF parameters (frequency, spread factor, coding rate, etc). Is it possible to change these parameters when in LoRaWan working mode? From the AT command list we know that it was possible to do that with the P2P mode.
Hi @emfpinto,
If it is only used for evaluating, the P2P function is not nesessary. As your colleague said, you can use LoRaWAN to evaluate too.
Hi @Ricardo,
Please help to confirm whether the region setting of LoRa node and LoRa gateway are different, or the enabled channels on LoRa node and LoRa gateway are different;
You can use “at+get_config=lora:status” to get the LoRa information, and use “at+get_config=lora:channel” to get all LoRa channels state.
Hi @Fomi,
the gateway is configured to operate in region EU868, listening at channel 1 (868.3 MHz), Bandwidth=125kHz, Spreadingt Factor=SF7 (128 chip/s), thus DataRate=5.
I also verified that RAK 7200 tracker is showing the same RF parameters by reading the output of both “at+get_config=lora:status” and “at+get_config=lora:channel” commands.
Console:
[LoRa]:Joined Successed!
OK *0,on,868100000,0,5; *1,on,868300000,0,5; *2,on,868500000,0,5; 3,off,0,0,0; 4,off,0,0,0; 5,off,0,0,0; 6,off,0,0,0; 7,off,0,0,0; *8,on,867100000,0,5; *9,on,867300000,0,5; *10,on,867500000,0,5; *11,on,867700000,0,5; *12,on,867900000,0,5; 13,off,0,0,0; 14,off,0,0,0; 15,off,0,0,0
OK Work Mode: LoRaWAN
Region: EU868
Send_interval: 5s
Auto send status: true.
Send_interval work at sleep
Join_mode: ABP
DevAddr: 12345678
AppsKey: A0000000000000000000000000000000
NwksKey: B0000000000000000000000000000000
Joined Network:true
IsConfirm: false
AdrEnable: true
RX2_CHANNEL_FREQUENCY: 869525000, RX2_CHANNEL_DR:0
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 5
Primeval Datarate: 5
UpLinkCounter: 0
I cannot see why I am not receiving anything, maybe I am missing something here about the LoRaWan protocol.
Thanks for your quick replies!
Hi @Ricardo
If you use LoRaWAN ABP mode ,you should make sure the three parameters(DevAddr,AppsKey,NwksKey) match the server.
I saw your 7200 work in auto send and sleep mode,can I see the detailed log of nodes?And what server did you test on? Does the gateway receive data?
Hi @leopold,
the network server and gateway is our own implemented version. In this stage I’m not interested in the network server at all to unmarshall and decrypt any packet according to the keys and device address for any high-level application.
The issue here is a very low-level one in the network stack: Our own custom gateway receives LoRa packets and prints out the bytes received (even if not decrypt using NwksKey and forward to an Application Server, we really don’t care about that right now) from other trackers (SEMTECH SX1272 for instance) but not from the RAK7200 tracker. By sharing the same RF parameters shouldn’t I be receiving any LoRa packet in any way in our gateway’s LoRA transceiver or am I missing something here :confused: ?
Hi @Ricardo
In that case you should confirm the frequency list of RAK7200 with “at+get_config=lora:channel”,
then see if the supported frequency points of the gateway match the frequency points that 7200 has turned on.
@leopold @Fomi
Do you know how to get the additional two digits of GPS data into The Things Network with the decoder? The decoder only shows 4 decimal places but the raw data in the serial port tool shows 6 decimal places.
TTN DATA
“gps”: {
“altitude”: “393.5m”,
“latitude”: “44.9833°”,
“longitude”: “-89.6449°”
DECODER SCRIPT
case 0x0188:// GPS
var gps = {};
gps.latitude = (parseTriple(str.substring(4, 10), 16) * 0.0001).toFixed(4) + “°”;
gps.longitude = (parseTriple(str.substring(10, 16), 16) * 0.0001).toFixed(4) + “°”;
gps.altitude = (parseTriple(str.substring(16, 22), 16) * 0.01).toFixed(1) + “m”;
myObj.gps = gps;
str = str.substring(22);
@focigod705
With AT command:
at+set_config=device:gps_format:X
X means: <0: LPP format which is only 4 decimal digits accuracy>
<1: 6 decimal digits accuracy>
Hi @JeroenKl,
I tried sending the command and found the following result.
at+set_config=device:gps_format:1
The AT Command is invalid.
Any other suggestions? Thanks for your help.
Is this AT command an update in the latest firmware? I am currently on 3.1.0.10.
Hi @focigod705,
Which version firmware are you using?
I think it may be a lower version so that this AT command can’t be used.
You can download the latest firmware and the bootloader here:
https://downloads.rakwireless.com/en/LoRa/RAK7200-Tracker/Firmware/
Then flash them into your RAK7200 according to the document:
https://doc.rakwireless.com/rak7200-lora-tracker/burning-the-bootloader
Thanks @JeroenKl and @Fomi. After updating the firmware I was able to send the command. Thank you both.
@Fomi, will I need to adjust the payload decoder for TTN?
Hi @focigod705,
Yes, we’re making another decoder for TTN now. :smile:
you can use
for 4 digits precision gps data.
If you increased the precision(6 digits), you should use
Wonderful. Thank you very much.
Hi @Fomi,
Can we expect a RUI based firmware soon?
Hi @Fomi,
Oh @JeroenKl,
I’m really sorry for late reply, especially your last post because i just see it…
About the new firmware for RAK7200 based one RUI, i’m afraid it will not be released soon.
Recently, my team are working on RAK modules linke RAK811, RAK4200, RAK4270, RAK4600, …
We want to focus on imporving these modules firstly (the first step), then improving RAK products like RAK7200 based on these modules’s new firmware (the second step). This is a re-optimized work.
Now, we are at the end of the first step, and the second step will start at the beginnig of the next month.
