@Nicholas - I currently have my RAK7200 plugged in to my laptop via USB.
When I plug it in, all three lights come on, and when data is transmitted, I see the blue “transmit” light flash as expected, however neither the “battery full” nor the “battery charging” lights are lit at any point during the charge/usage process.
As an example, at the moment it is charging but I don’t have the red light on that you mention.
The transmit power value doesn’t persist between reboots. I set it to 5 which I found conflicting information in LORA as to whether 0 is more or less db than 5 (anyone have an idea?). Also, it seems that on DR 0, there isn’t enough bandwidth to send the 53 bytes that the 7200 tries to send. Therefore, I have to disable ADR. Should there be an option to mask out certain DR’s maybe like there are for channels? I’m on 3.1.0.10 (indicator lights still don’t work)
Hi, I made a mistake. in OTAA mode I entered the dev_addr. Now my RAK7200 can no longer join. How can I delete the dev_addr?
If there are no alternatives I can also delete all the configuration and write it again but I have not found any of these commands. Thank you all!
I followed this and the Measurments field mentioned in the above reply.
Defining TTN devices
Before you add the device to Signomix, make sure that using the TTN console:
you have added the device to a selected TTN application
you have assigned the Device EUI, Application EUI, App Key values according to the device’s technical parameters
you have added an Application EUI device to the Application EUIS parameter
you have checked that TTN application has a defined HTTP integration with URL equal http://signomix.com/api/ttn
You can add the device to Signomix by selecting “User Profile > Device Management” from the menu and then clicking the “+” icon. After selecting “UNDEFINED” device line, select the type “TTN”.
Pay attention to the following when defining the device:
Key
The value of Authorization header specified in TTN application’s HTTP integration channel definition is entered in this field.
We’ve just added the changelog, please check.
The mainly change is this AT command “at+set_config=device:gps_format:X”:
X means: <0: LPP format which is only 4 decimal digits accuracy>
<1: 6 decimal digits accuracy>
My RAK7200 (latest software flashed) usually sends the correct GPS coordinates for hours. Unfortunately sometimes and at random moments coordinates are sent that make no sense, for example latitude 740.5588 and longitude 9.8819. Same with battery power so this issue is not GPS related. Is this a known issue and does anyone have a solution?
After using the RAK7200 for a few months I have to say that it has been my worst hardware experience since a long time. If it was my first introduction to LoRaWAN, I would even stop using LoRa immediately. I still feel like a beta tester for a product that i.m.o. came prematurely on the market and after months of struggling and many firmware updates the tracker seems still not working properly.
Sorry to say I have lost faith in RAKwireless products.
Don’t worry Hans. We take full responsibility for the product. As you can see the thread from other community member, they use the device with latest firmware seems no problem. Do you think we can send a new one to you and you return this failure one to us for further analysis? We really look forward to work with community to continue improve and provide the best lorawan device to industry. My email is [email protected]
