Actually, if you only want upgrade the firmware for RAK7200, you needn’t to flash the bootloader again, and surely you needn’t to use STM32 CubeProgrammer. You just need to do as follow:
Let RAK7200 work in BOOT mode by sending an AT command to it;
Upgrade the firmware using RAK firmware upgrade tool;
More details you can find in the above document.
I’m sorry to say but the new firmware 3.1.0.6 is not working very well.
It is working less comparing with 3.1.0.5. On my trip to work I’ve got only 1 valid TTN mapper GPS hit.
Also without GPS the hit performance is terrible even with external antenna. As previous reported the node is not connecting always to a gateway (in range).
Issues:
GPS not always valid, 1 out of 10 is sent (during movement)
LED’s are not working
Not connecting to gateways within range (TTGO-T-beam at the same moment it is) (during movement)
I had all kinds of issues with the LPP decoder not working properly on that version.
I’ll upgrade to 3.1.0.6 and see what happens, but I’ve got to say I’m less than impressed with this device so far, it really does feel like Alpha quality instead of the finished product that I paid for.
It seems that the latest firmware works well and the GPS can be shown in Cayenne correctly.
But there is still an issue, the GPS position are changing all the time even if we don’t move the device.
We’ll debug this issue ASAP.
The tracker works indeed when you are NOT moving, as soon as you are moving causes no GPS lock after wake up.
During fixed position sometimes you will have an incorrect lock. Indeed the same as you discovered.
See below:
Happy to test it but I need to have my laptop installed in my car otherwise I cannot get the statements from the UART.
Not able to perform it today but tomorrow I can and will let you know.
Any updates, news with regards the other reported issues?
In your cayenne dashboard I see you’ve got a temp/baro sensor working with the 7200. Is this a different hardware version as you reported the versions currently shipped doesn’t have this sensor?
Anyone else testing this device in the US? I’m having problems with it connecting to a known good Lora access point. I get the join packet, the serial interface states it joins successfully (OTAA), but then when it tries to send GPS data, I get a Unknown Network Error: 8, then (as of firmware 3.1.0.6) the 7200 says it sends GPS data but nothing is received at the access point. It’s never successfully transmitted GPS since I got this device. One thing I’m noticing is that no matter how far/close I am or with multiple antennas (factory or add on) the device seems to be hitting the max duty cycle time of 371 seconds at SF 10. The TTN console reports that any packet no matter the distance from the AP is using 370.7 seconds to transmit. I’m wondering if that has something to do with this issue?
Also, when masking out channels, a restart is required for it to save and use them - you may want to add that to the AT command directions.
I’m in the identical situation as you here in the US. Using 3.1.06 I can join okay and it shows up on the TTN console. But no data is sent. I get Unknown Network Error: 8 and then [LoRa]: Send out <data_len:32bytes>. All the channel assignments look correct (8 – 15 are on) others are off, except 64 – 71 are also on. I think only 64 should be on, so I disabled 65 – 71, verified channels and then did a restart as you mentioned. After it came up 64 – 71 were back on again. I should mention I’m inside and the GPS is not locked.
Had some success sending data (32 bytes worth). The default data rate of 0 doesn’t allow sending a payload that large. I set my RAK to a data rate of 1 using “at+set_config=lora:dr:1”. Now all the data gets to the TTN console. Hope this helps.
