RAK 7204 LPP Payload - Indoor Air Quality
Is the Payload called (by default) Analogue Input 4 in Cayenne, the following IAQ (Indoor Air Quality) ?
I get a value of about 24.25
You can check this out.
Hi,@patmolloy
About the Air Quality of RAK7204(with BME680 sensor) isn’t gived IAQ but the air resistance value. https://community.bosch-sensortec.com/t5/Knowledge-base/BME680-gas-sensor-series-design-guide/tac-p/7199#M32
How to convert to IAQ you could refer to their official library:https://github.com/BoschSensortec/BSEC-Arduino-library.
Thanks!
This is not so good, though. I do not see a way on TTN (or Cayenne) to get from Air Resistance to IAQ. I cannot use any of their libraries in the LoRaWAN use case.
Pat
I’m interested too!
I understand it would require a converter from the measurement in ohms to IAQ.
Quite right?
BME680 IAQ Example
Using the BME680 to measure temperature, pressure, humidity and air quality.
The sensor is used to obtain the so-called Gas Resistance and then calculate an Index of Air Quality (IAQ) from a combination of humidity and the gas content readings of the air, optionally temperature could be added too, but omittied in this example.
The index is a function of humidity which contributes up to 25% and gas concentrations that contributes up to 75%. See slide1.jpg for details of the IAQ index formulation.
In this current version only Humidity and Gas concentrations are used for the index, but adding temperature woudl be straightforward on the basis that temperatures for humans that are too high or low add to the overal Air Quality index along with Humidity and Gas concetrations.
Humidity is measured between 0 - 100% and is universally accepted as being optimal when it is 40% and where in this index the contribution will be 0, but at a Humidity reading of 0%, the contribution increases to 25% and similarly when humidity reaches 100% it contributes 25% to the index. See Slide1 for details.
Gas concentrations for normal breathable air with no pollutants (no adverse gases) corresponds to the sensors highest resitance output of 50,000 ohms or more. The sensor normally outputs a Gas resistance value ranging from a low of 50ohm to a high of 50,000ohm and beyond. A linear relationship is assumed and the output scaled accordingly between 0 and 75% for the range 50-50,000 ohms.
The result of combining humidity and gas measurements into an in index is a qualitative and so-called IAQ - Indoor Air Quality index value scaled from 0-100% (where 100% is good). This is then scaled again from 0-500 where a 500 value is bad and descriptive values are applied in stages from good to hazardous air quality.
There is no definitive (ISO Standard) method for calculating an IAQ.
© d.l.bird 2018 all rights reserved and as per the Licence agreements listed in my software.
This IAQ and the ideas and concepts is Copyright © David Bird 2018. All rights to this IAQ and software are reserved. Any redistribution or reproduction of any part or all of the contents in any form is prohibited other than the following:
  1. You may print or download to a local hard disk extracts for your personal and non-commercial use only.
  2. You may copy the content to individual third parties for their personal use, but only if you acknowledge the author David Bird as the source of the material.
  3. You may not, except with my express written permission, distribute or commercially exploit the content.
  4. You may not transmit it or store it in any other website or other form of electronic retrieval system for commercial purposes.
The above copyright (‘as annotated’) notice and this permission notice shall be included in all copies or substantial portions of the IAQ index and Software and where the software use is visible to an end-user.
